Ground state solitary waves local controllability for the nonlinear focusing Schrödinger equation in the mass critical and slighlty mass subcritical regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
In this paper, we prove the exact local controllability around different ground state solitary wave for the slightly subcritical mass and mass critical nonlinear Schrödinger equation. More precisely, if Q c1 and Q c2 denotes the ground states with two different scaling, we prove the exact local controllability from Q c1 to Q c2 in a minimal time depending on c 1 and c 2. The results presented relies on the blow-up profile in the mass slightly supercritical case and mass critical case.
ContNLSv7.pdf (587.27 Ko) Télécharger le fichier
hal-03141045 , version 1 (14-02-2021)
hal-03141045 , version 2 (01-03-2021)
  • HAL Id : hal-03141045 , version 2
Ludovick Gagnon. Ground state solitary waves local controllability for the nonlinear focusing Schrödinger equation in the mass critical and slighlty mass subcritical regime. 2021. ⟨hal-03141045v2⟩
71 Consultations
65 Téléchargements
