Design of a mode converter using thin resonant ligaments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2022
The goal of this work is to design an acoustic mode converter. More precisely, the wave number is chosen so that two modes can propagate. We explain how to construct geometries such that the energy of the modes is completely transmitted and additionally the mode 1 is converted into the mode 2 and conversely. To proceed, we work in a symmetric waveguide made of two branches connected by two thin ligaments whose lengths and positions are carefully tuned. The approach is based on asymptotic analysis for thin ligaments around resonance lengths. We also provide numerical results to illustrate the theory.
ChHeNa.pdf (1.36 Mo) Télécharger le fichier
hal-03141128 , version 1 (15-02-2021)
hal-03141128 , version 2 (22-12-2021)
Lucas Chesnel, Jérémy Heleine, Sergei A Nazarov. Design of a mode converter using thin resonant ligaments. Communications in Mathematical Sciences, 2022, 20 (2), pp.425-445. ⟨10.4310/CMS.2022.v20.n2.a6⟩. ⟨hal-03141128v2⟩
89 Consultations
159 Téléchargements
