StrainFLAIR: strain-level profiling of metagenomic samples using variation graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PeerJ Année : 2021
Current studies are shifting from the use of single linear references to representation of multiple genomes organised in pangenome graphs or variation graphs. Meanwhile, in metagenomic samples, resolving strain-level abundances is a major step in microbiome studies, as associations between strain variants and phenotype are of great interest for diagnostic and therapeutic purposes. We developed StrainFLAIR with the aim of showing the feasibility of using variation graphs for indexing highly similar genomic sequences up to the strain level, and for characterizing a set of unknown sequenced genomes by querying this graph. On simulated data composed of mixtures of strains from the same bacterial species Escherichia coli, results show that StrainFLAIR was able to distinguish and estimate the abundances of close strains, as well as to highlight the presence of a new strain close to a referenced one and to estimate its abundance. On a real dataset composed of a mix of several bacterial species and several strains for the same species, results show that in a more complex configuration StrainFLAIR correctly estimates the abundance of each strain. Hence, results demonstrated how graph representation of multiple close genomes can be used as a reference to characterize a sample at the strain level.
peerj-11884.pdf (2.56 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03141144 , version 1 (23-08-2021)
Paternité
Kévin da Silva, Nicolas Pons, Magali Berland, Florian Plaza Oñate, Mathieu Almeida, et al.. StrainFLAIR: strain-level profiling of metagenomic samples using variation graphs. PeerJ, 2021, 9, pp.e11884. ⟨10.7717/peerj.11884⟩. ⟨hal-03141144⟩
99 Consultations
167 Téléchargements
