New interface
Journal articles
Intersecting fractures in porous media: theoretical and numerical analysis
Abstract : This paper studies a model for flow in a fractured porous medium with intersecting fractures. The fractures are treated as lower-dimensional manifolds along which physical transmission conditions express the pressure jump and the continuity of the flux across the fractures. Specific attention is borne to the conditions when several fractures intersect. The resulting system is discretized with mixed finite element, and the well-posedness of both the continuous and the disctete problems are proved. Then a domain decomposition method is formulated, so that the problem is reduced to the set of fractures, and a simple preconditioner is proposed. Numerical results exemplify the performance of the method.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/hal-03141968
Contributor : Michel Kern Connect in order to contact the contributor
Submitted on : Thursday, October 21, 2021 - 12:27:14 AM
Last modification on : Friday, August 12, 2022 - 3:43:26 AM
File
fracturesAKMR_HALv2 (1).pdf
Identifiers
Citation
Laila Amir, Michel Kern, Zoubida Mghazli, Jean E Roberts. Intersecting fractures in porous media: theoretical and numerical analysis. Applicable Analysis, 2021, ⟨10.1080/00036811.2021.1981878⟩. ⟨hal-03141968v2⟩
Share
Metrics
Record views
106
Files downloads
121
