Computing isogenies between Jacobians of hyperelliptic curves of arbitrary genus via differential equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Let $p$ be an odd prime number and be an integer coprime to $p$. We survey an algorithm for computing explicit rational representations of $(\ell,...,\ell)$-isogenies between Jacobians of hyperelliptic curves of arbitrary genus over an extension $K$ of the field of $p$-adic numbers $\mathbb{Q}_p$. The algorithm has a quasi-linear complexity in $\ell$ as well as in the genus of the curves.
Arbitrary_genus.pdf (138.78 Ko) Télécharger le fichier
hal-03142205 , version 1 (15-02-2021)
Elie Eid. Computing isogenies between Jacobians of hyperelliptic curves of arbitrary genus via differential equations. 2021. ⟨hal-03142205⟩
90 Consultations
35 Téléchargements
