Towards better systems programming in OCaml with out-of-heap allocation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The current multicore OCaml implementation bans so-called "naked pointers", pointers to outside the OCaml heap unless they follow drastic restrictions. A backwards-incompatible change has been proposed to make way for the new multicore GC in OCaml. I argue that out-of-heap pointers are not an anomaly, but are part of a better systems programming future.
ml2020-paper8.pdf (213.89 Ko) Télécharger le fichier
hal-03142386 , version 1 (16-02-2021)
  • HAL Id : hal-03142386 , version 1
Guillaume Munch-Maccagnoni. Towards better systems programming in OCaml with out-of-heap allocation. ML Workshop 2020, Aug 2020, Jersey City, United States. pp.1-6. ⟨hal-03142386⟩
86 Consultations
406 Téléchargements
