Reduced-Order Fast Converging Observers for Systems with Discrete Measurements and Measurement Error - Archive ouverte HAL Access content directly
Journal Articles Systems and Control Letters Year : 2021
Michael Malisoff
  • Function : Author
  • PersonId : 1091208
Zhong-Ping Jiang
  • Function : Author
  • PersonId : 1091209
We provide novel reduced-order observer designs for continuous-time nonlinear systems with measurement error. Our first result applies to systems with continuous output measurements, and provides observers that converge in a fixed finite time that is independent of the initial state when the measurement error is zero. Our second result applies under discrete measurements, and provides observers that converge asymptotically with a rate of convergence that is proportional to the negative of the logarithm of the size of a sampling interval. Our observers satisfy an enhanced input-to-state stability property with respect to the measurement error, in which an overshoot term only depends on a recent history of the measurement error. We illustrate our observers using a model of a single-link robotic manipulator coupled to a DC motor with a nonrigid joint, and in a pendulum example.
pourhal.pdf (734.34 Ko) Télécharger le fichier
Dates and versions
hal-03144750 , version 1 (17-02-2021)
Identifiers
  • HAL Id : hal-03144750 , version 1
Cite
Frederic Mazenc, Michael Malisoff, Zhong-Ping Jiang. Reduced-Order Fast Converging Observers for Systems with Discrete Measurements and Measurement Error. Systems and Control Letters, 2021. ⟨hal-03144750⟩
33 View
239 Download
Share
