On the logical structure of choice and bar induction principles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We develop an approach to choice principles and their contrapositive bar-induction principles as extensionality schemes connecting an "effective" or "intensional" view of respectively ill-and well-foundedness properties to an "extensional" or "ideal" view of these properties. After classifying and analysing the relations between different intensional definitions of ill-foundedness and well-foundedness, we introduce, for a domain A, a codomain B and a "filter" T on finite approximations of functions from A to B, a generalised form GDC(A,B,T) of the axiom of dependent choice and dually a generalised bar induction principle GBI(A,B,T) such that: - GDC(A,B,T) intuitionistically captures • the strength of the general axiom of choice expressed as ∀a ∃b R(a, b) ⇒ ∃α ∀a R(a, α(a))) when T is a filter that derives point-wise from a relation R on A × B without introducing further constraints, • the strength of the Boolean Prime Filter Theorem / Ultrafilter Theorem if B is the two-element set Bool, • the strength of the axiom of dependent choice if A = N, and up to weak classical reasoning • the (choice) strength of Weak König’s Lemma if A = N and B = Bool. - GBI(A,B,T) intuitionistically captures • the strength of Gödel’s completeness theorem in the form validity implies provability when B = Bool, • the strength of the Bar Induction when A = N, • the (choice) strength of the Weak Fan Theorem when A = N and B = Bool. Contrastingly, even though GDC(A,B,T) and GBI(A,B,T) smoothly capture several variants of choice and bar induction, some instances are inconsistent, e.g. when A is Bool^N and B is N.
hal-mar21.pdf (679.58 Ko) Télécharger le fichier
hal-03144849 , version 1 (17-02-2021)
hal-03144849 , version 2 (15-03-2021)
hal-03144849 , version 3 (12-05-2021)
hal-03144849 , version 4 (18-06-2021)
hal-03144849 , version 5 (05-07-2022)
  • HAL Id : hal-03144849 , version 2
Nuria Brede, Hugo Herbelin. On the logical structure of choice and bar induction principles. 2021. ⟨hal-03144849v2⟩
362 Consultations
556 Téléchargements
