Machine Learning-Based Pipeline for High Accuracy Bioparticle Sizing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Micromachines Année : 2020
High accuracy measurement of size is essential in physical and biomedical sciences. Various sizing techniques have been widely used in sorting colloidal materials, analyzing bioparticles and monitoring the qualities of food and atmosphere. Most imaging-free methods such as light scattering measure the averaged size of particles and have difficulties in determining non-spherical particles. Imaging acquisition using camera is capable of observing individual nanoparticles in real time, but the accuracy is compromised by the image defocusing and instrumental calibration. In this work, a machine learning-based pipeline is developed to facilitate a high accuracy imaging-based particle sizing. The pipeline consists of an image segmentation module for cell identification and a machine learning model for accurate pixel-to-size conversion. The results manifest a significantly improved accuracy, showing great potential for a wide range of applications in environmental sensing, biomedical diagnostical, and material characterization.
micromachines-11-01084-v3.pdf (4.34 Mo) Télécharger le fichier
hal-03144923 , version 1 (19-02-2021)
Shaobo Luo, Yi Zhang, Kim Truc Nguyen, Shilun Feng, Yuzhi Shi, et al.. Machine Learning-Based Pipeline for High Accuracy Bioparticle Sizing. Micromachines, 2020, 11 (12), pp.1084. ⟨10.3390/mi11121084⟩. ⟨hal-03144923⟩
147 Consultations
68 Téléchargements
