Clinical validation of a computer‐based approach for the quantification of the skin ageing process of women using in vivo confocal microscopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the European Academy of Dermatology and Venereology Année : 2021
Reflectance confocal microscopy (RCM) is a powerful tool to visualize the skin layers at cellular resolution up to a depth of 200µm. A semi-quantitative score of skin aging from RCM images has been previously published, requiring visual assessment of the images by experienced dermatologists. In this article we propose new computer-based methods to automatically quantify the skin aging process on RCM image.
Letter_RCM_Draft.pdf (3.12 Mo) Télécharger le fichier
hal-03144931 , version 1 (18-02-2021)
Julie Robic, Alex Nkengne, Benjamin Perret, Michel Couprie, Hugues Talbot, et al.. Clinical validation of a computer‐based approach for the quantification of the skin ageing process of women using in vivo confocal microscopy. Journal of the European Academy of Dermatology and Venereology, 2021, 35 (1), ⟨10.1111/jdv.16810⟩. ⟨hal-03144931⟩
99 Consultations
83 Téléchargements
