Translation validation of a pattern-matching compiler
We propose an algorithm for the translation validation of a pattern matching compiler for a small subset of the OCaml pattern matching features. Given a source program and its compiled version the algorithm checks wheter the two are equivalent or produce a counter example in case of a mismatch.
Our equivalence algorithm works with decision trees. Source patterns are converted into a decision tree using matrix decomposition. Target programs, described in a subset of the Lambda intermediate representation of the OCaml compiler, are turned into decision trees by applying symbolic execution.
