Classical Rayleigh-Jeans condensation of light waves: Observation and thermodynamic characterization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2020
Theoretical studies on wave turbulence predict that a purely classical system of random waves can exhibit a process of condensation, which originates in the singularity of the Rayleigh-Jeans equilibrium distribution. We report the experimental observation of the transition to condensation of classical optical waves propagating in a multimode fiber, i.e., in a conservative Hamiltonian system without thermal heat bath. In contrast to conventional self-organization processes featured by the nonequilibrium formation of nonlinear coherent structures (solitons, vortices,…), here the self-organization originates in the equilibrium Rayleigh-Jeans statistics of classical waves. The experimental results show that the chemical potential reaches the lowest energy level at the transition to condensation, which leads to the macroscopic population of the fundamental mode of the optical fiber. The near-field and far-field measurements of the condensate fraction across the transition to condensation are in quantitative agreement with the Rayleigh-Jeans theory. The thermodynamics of classical wave condensation reveals that the heat capacity takes a constant value in the condensed state and tends to vanish above the transition in the normal state. Our experiments provide the first demonstration of a coherent phenomenon of self-organization that is exclusively driven by optical thermalization toward the Rayleigh-Jeans equilibrium.
RJ_condensation.pdf (684.52 Ko) Télécharger le fichier
hal-02998384 , version 1 (18-11-2020)
Kilian Baudin, Adrian Fusaro, Katarzyna Krupa, Josselin Garnier, Sergio Rica, et al.. Classical Rayleigh-Jeans condensation of light waves: Observation and thermodynamic characterization. Physical Review Letters, 2020, 125, pp.244101. ⟨10.1103/PhysRevLett.125.244101⟩. ⟨hal-02998384⟩
189 Consultations
157 Téléchargements
