A strong call-by-need calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a call-by-need λ-calculus that enables strong reduction (that is, reduction inside the body of abstractions) and guarantees that arguments are only evaluated if needed and at most once. This calculus uses explicit substitutions and subsumes the existing strong-call-by-need strategy, but allows for more reduction sequences, and often shorter ones, while preserving the neededness. The calculus is shown to be normalizing in a strong sense: Whenever a λ-term t admits a normal form n in the λ-calculus, then any reduction sequence from t in the calculus eventually reaches the normal form n. We also exhibit a restriction of this calculus that has the diamond property and that only performs reduction sequences of minimal length, which makes it systematically better than the existing strategy.
main.pdf (663.72 Ko) Télécharger le fichier
scbn-abella.zip (10.52 Ko) Télécharger le fichier
Format : Autre
Commentaire : Abella formalization associated to the paper.
hal-03149692 , version 1 (23-02-2021)
hal-03149692 , version 2 (04-05-2021)
Thibaut Balabonski, Antoine Lanco, Guillaume Melquiond. A strong call-by-need calculus. Proceedings of the 6th International Conference on Formal Structures for Computation and Deduction, Jul 2021, Buenos Aires, Argentina. pp.1-22, ⟨10.4230/LIPIcs.FSCD.2021.9⟩. ⟨hal-03149692v1⟩
409 Consultations
578 Téléchargements
