HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Are Search Engines Biased? Detecting and Reducing Bias using Meta Search Engines
Abstract : The search neutrality debate stems from content or service providers complaining about being discriminated and therefore losing market shares due to an unfairly low ranking given by search engines. Those questions stress the need for methodologies and tools to verify bias in search engine rankings and analyze their potential impact. We develop in this paper a simple yet effective framework comparing the results of existing search engines. We present statistical tests based on outlier detection pointing out potential biases, and introduce two meta engines aiming at reducing bias. All this is implemented in a publicly-available tool from which extensive comparisons and bias investigations are carried out.
Complete list of metadata
https://hal.inria.fr/hal-03150446
Contributor : Bruno Tuffin Connect in order to contact the contributor
Submitted on : Tuesday, February 23, 2021 - 6:36:37 PM
Last modification on : Monday, April 4, 2022 - 9:28:24 AM
Long-term archiving on: : Monday, May 24, 2021 - 8:52:21 PM
File
main.pdf
Identifiers
  • HAL Id : hal-03150446, version 1
Citation
Patrick Maillé, Gwen Maudet, Mathieu Simon, Bruno Tuffin. Are Search Engines Biased? Detecting and Reducing Bias using Meta Search Engines. 2021. ⟨hal-03150446⟩
Share
Metrics
Record views
210
Files downloads
721
