HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
Nonlinear Modal Analysis of Frictional Ring Damper for Compressor Blisk
Abstract : The use of integrally blisk is becoming popular because of the advantages in aerodynamic efficiency and mass reduction. However, in an integrally blisk, the lack of the contact interface leads to a low structural damping compared to an assembled bladed disk. One emerging damping technique for the integrally blisk is based on the use of friction ring damper, which exploits the contact interfaces at the underneath of the disk. In this paper, three different geometries of the ring dampers are investigated for damping enhancement of a blisk. A full-scale compressor blisk is considered as a case study where a node-to-node contact model is used to compute the contact forces. The dynamic behavior of the blisk with the ring damper is investigated by using nonlinear modal analysis, which allows a direct estimation of the damping generated by the friction interface. The damping performance for the different ring dampers is evaluated and compared. It appears that the damping efficiency as well as the shift in the resonant frequency for the different geometries is highly related to the nodal diameter and contact pressure/gap distributed within contact interface. The geometry of the ring damper has significant impact on the damping performance.
Complete list of metadata
https://hal.inria.fr/hal-03151035
Contributor : Enora Denimal Connect in order to contact the contributor
Submitted on : Wednesday, February 24, 2021 - 1:46:06 PM
Last modification on : Tuesday, January 18, 2022 - 2:26:07 PM
Long-term archiving on: : Tuesday, May 25, 2021 - 6:36:48 PM
File
GTP_2021_Sun.pdf
Identifiers
Citation
Yekai Sun, Jie Yuan, Enora Denimal, Loic Salles. Nonlinear Modal Analysis of Frictional Ring Damper for Compressor Blisk. Journal of Engineering for Gas Turbines and Power, American Society of Mechanical Engineers, 2021, 143 (3), pp.1-8. ⟨10.1115/1.4049761⟩. ⟨hal-03151035⟩
Share
Metrics
Record views
49
Files downloads
128
