Spiraling of sub-Riemannian geodesics around the Reeb flow in the 3D contact case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We consider a closed three-dimensional contact sub-Riemannian manifold. The objective of this note is to provide a precise description of the sub-Riemannian geodesics with large initial momenta: we prove that they "spiral around the Reeb orbits", not only in the phase space but also in the configuration space. Our analysis is based on a normal form along any Reeb orbit due to Melrose.
spiraling.pdf (334.9 Ko) Télécharger le fichier
hal-03151365 , version 1 (24-02-2021)
  • HAL Id : hal-03151365 , version 1
Yves Colin de Verdière, Luc Hillairet, Emmanuel Trélat. Spiraling of sub-Riemannian geodesics around the Reeb flow in the 3D contact case. 2021. ⟨hal-03151365⟩
142 Consultations
75 Téléchargements
