Classification with abstention but without disparities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Classification with abstention has gained a lot of attention in recent years as it allows to incorporate human decision-makers in the process. Yet, abstention can potentially amplify disparities and lead to discriminatory predictions. The goal of this work is to build a general purpose classification algorithm, which is able to abstain from prediction, while avoiding disparate impact. We formalize this problem as risk minimization under fairness and abstention constraints for which we derive the form of the optimal classifier. Building on this result, we propose a post-processing classification algorithm, which is able to modify any off-the-shelf score-based classifier using only unlabeled sample. We establish finite sample risk, fairness, and abstention guarantees for the proposed algorithm. In particular, it is shown that fairness and abstention constraints can be achieved independently from the initial classifier as long as sufficiently many unlabeled data is available. The risk guarantee is established in terms of the quality of the initial classifier. Our post-processing scheme reduces to a sparse linear program allowing for an efficient implementation, which we provide. Finally, we validate our method empirically showing that moderate abstention rates allow to bypass the risk-fairness trade-off.
hal-03152091 , version 1 (25-02-2021)
Nicolas Schreuder, Evgenii Chzhen. Classification with abstention but without disparities. Conference on Uncertainty in Artificial Intelligence (UAI 2021), Jul 2021, Virtual conference, Australia. ⟨hal-03152091⟩
80 Consultations
0 Téléchargements
