Abstract : We present EverCrypt: a comprehensive collection of verified, high-performance cryptographic functionalities available via a carefully designed API. The API provably supports agility (choosing between multiple algorithms for the same functionality) and multiplexing (choosing between multiple implementations of the same algorithm). Through abstraction and zero-cost generic programming, we show how agility can simplify verification without sacrificing performance, and we demonstrate how C and assembly can be composed and verified against shared specifications. We substantiate the effectiveness of these techniques with new verified implementations (including hashes, Curve25519, and AES-GCM) whose performance matches or exceeds the best unverified implementations. We validate the API design with two high-performance verified case studies built atop EverCrypt, resulting in line-rate performance for a secure network protocol and a Merkle-tree library, used in a production blockchain, that supports 2.7 million insertions/sec. Altogether, EverCrypt consists of over 124K verified lines of specs, code, and proofs, and it produces over 29K lines of C and 14K lines of assembly code.
