Fertilities. On the Collecting Paths of Oasis Women (Plant World, Cosmic Resonators, Collective Care
Fertilidades. Por los senderos de recolecta de las mujeres de los oasis (universo vegetal, resonadores cósmicos, asistencia colectiva)
Fertilités. Sur les chemins de collecte des femmes oasiennes (univers végétal, résonateurs cosmiques, soins collectifs)
This text presents a description of the plant world of an oasis in pre-Saharan Morocco (Souss region) by emphasizing the daily presence of elderly women from very modest backgrounds, who come daily to weed and collect spontaneous plants. These women have a special relationship with the latter and transpose their nourishing, prophylactic, therapeutic or magical powers to the oasis community as a whole. But the question arises of what will happen to this field of relationships, so integrated into fertility cycles, in the wake of the structural transformations and modernization projects currently under way in oasis areas. These projects, while supporting environmentalist objectives, affirm a modality of qualification of the soil and its exploitation that tends to eclipse the presence of these women, neglecting at the same time the whole cosmological background on which their attentive gestures draw, and the sensate permeability of the oasis plant universe of which they are the custodians.
Este artículo presenta un panorama del universo vegetal de un oasis de Maruecos pre-sahariano (región del Souss) enfatizando la presencia de mujeres mayores provenientes de medios muy modestos que cotidianamente vienen a desherbar y recolectar plantas silvestres. Estas mujeres mantienen una relación privilegiada con las plantas y transmiten su poder nutricio, profiláctico y terapéutico o mágico a la comunidad del oasis en su conjunto. Sin embargo una pregunta surge: ¿qué va a suceder con ese campo de relaciones integradas a los ciclos de la fertilidad a lo largo de las transformaciones estructurales y de los proyectos de modernización que esos espacios de oasis conocen actualmente? Esos proyecto, portadores de objetivos medioambientales, despliegan un modo de evaluación del suelo y de su explotación que tiende a eclipsar la presencia de esas mujeres, ignorando de paso el rico trasfondo cosmológico en el que se configuran sus gestos solícitos y la permeabilidad sensible al universo vegetal del oasis del cual son las guardianas.
Cet article brosse un tableau de l’univers végétal d’une oasis du Maroc présaharien (région du Souss) en mettant l’accent sur la présence de femmes âgées issues d’un milieu très modeste venant quotidiennement désherber et collecter des plantes spontanées. Ces femmes entretiennent un lien privilégié avec ces dernières et transmettent leurs pouvoirs nourriciers, prophylactiques, thérapeutiques ou magiques à la communauté oasienne dans son ensemble. Mais une question se pose : que va-t-il advenir de ce champ de relations intégrées aux cycles de fertilité au fil des transformations structurelles et des projets de modernisation que connaissent actuellement les espaces oasiens ? Ces projets, tout en étant porteurs d’objectifs environnementalistes, attestent d’une modalité de qualification du sol et de son exploitation qui tend à éclipser la présence de ces femmes, négligeant au passage l’arrière-plan cosmologique foisonnant sur lequel se dessinent leurs gestes attentionnés et la perméabilité sensible à l’univers végétal oasien dont elles sont les gardiennes.
Breviglieri_2020_Fertilites_Sur_les_chemins_de_collecte.pdf (64.25 Mo)
Télécharger le fichier
Commentaire : Bonjour, le fichier précédent avait une erreur de nommage dans le nom de l'auteur. Merci de le remplacer par celui-ci. Bien cdt
