An algebraic approach to the Rank Support Learning problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Rank-metric code-based cryptography relies on the hardness of decoding a random linear code in the rank metric. The Rank Support Learning problem (RSL) is a variant where an attacker has access to N decoding instances whose errors have the same support and wants to solve one of them. This problem is for instance used in the Durandal signature scheme. In this paper, we propose an algebraic attack on RSL which clearly outperforms the previous attacks to solve this problem. We build upon Bardet et al., Asiacrypt 2020, where similar techniques are used to solve MinRank and RD. However, our analysis is simpler and overall our attack relies on very elementary assumptions compared to standard Gröbner bases attacks. In particular, our results show that key recovery attacks on Durandal are more efficient than was previously thought.
arxiv-v1.pdf (255.33 Ko) Télécharger le fichier
hal-03158460 , version 1 (04-03-2021)
hal-03158460 , version 2 (23-03-2021)
Magali Bardet, Pierre Briaud. An algebraic approach to the Rank Support Learning problem. 2021. ⟨hal-03158460v1⟩
184 Consultations
413 Téléchargements
