Learning the sampling density in 2D SPARKLING MRI acquisition for optimized image reconstruction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The SPARKLING algorithm was originally developed for accelerated 2D magnetic resonance imaging (MRI) in the compressed sensing (CS) context. It yields non-Cartesian sampling trajectories that jointly fulfill a target sampling density while each individual trajectory complies with MR hardware constraints. However, the two main limitations of SPARKLING are first that the optimal target sampling density is unknown and thus a user-defined parameter and second that this sampling pattern generation remains disconnected from MR image reconstruction thus from the optimization of image quality. Recently, datadriven learning schemes such as LOUPE have been proposed to learn a discrete sampling pattern, by jointly optimizing the whole pipeline from data acquisition to image reconstruction. In this work, we merge these methods with a state-of-the-art deep neural network for image reconstruction, called XPDNET, to learn the optimal target sampling density. Next, this density is used as input parameter to SPARKLING to obtain 20x accelerated non-Cartesian trajectories. These trajectories are tested on retrospective compressed sensing (CS) studies and show superior performance in terms of image quality with both deep learning (DL) and conventional CS reconstruction schemes.
main.pdf (1.74 Mo) Télécharger le fichier
README.md (143 B) Télécharger le fichier
hal-03158831 , version 1 (04-03-2021)
hal-03158831 , version 2 (31-05-2021)
Chaithya Giliyar Radhakrishna, Zaccharie Ramzi, Philippe Ciuciu. Learning the sampling density in 2D SPARKLING MRI acquisition for optimized image reconstruction. 2021 29th European Signal Processing Conference (EUSIPCO), IEEE, Aug 2021, Dublin, Ireland. ⟨hal-03158831v2⟩
190 Consultations
284 Téléchargements
