Boundary and In-Domain Control for Large-Scale Urban Traffic Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Liudmila Tumash
This paper presents a novel approach to design control for traffic on large-scale urban networks by analyzing the structure of one single partial differential equation (PDE). In particular, we elaborate a method that represents a curvilinear coordinate transformation translating a 2D conservation law into a parametrized set of equations each having a structure of inhomogeneous 1D LWR equation. This resulting system can be explicitly analyzed for traffic evolving on urban networks of arbitrary size. As an application example, we demonstrate how the 2D model in curvilinear coordinates can be used to design two different controllers for urban traffic. First, a boundary controller is designed to track any desired space- and timedependent vehicle density profile with the help of HamiltonJacobi formalism. Second, we design an in-domain variable speed limit (VSL) controller that steers traffic flow such that any space-varying equilibrium can be achieved. We validate the control results numerically using the structure of Grenoble downtown.
TAC_2D_revised_v1.pdf (2.08 Mo) Télécharger le fichier
hal-03167733 , version 1 (12-03-2021)
hal-03167733 , version 2 (24-10-2021)
  • HAL Id : hal-03167733 , version 2
Liudmila Tumash, Carlos Canudas de Wit, Maria Laura Delle Monache. Boundary and In-Domain Control for Large-Scale Urban Traffic Networks. 2021. ⟨hal-03167733v2⟩
170 Consultations
109 Téléchargements
