Control of Average and Deviation in Large-Scale Linear Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2022
Denis Nikitin
Paolo Frasca
This paper deals with the problem of controlling the average state of a large-scale linear network to a constant reference value. We design an output-feedback controller such that no information about state vector or system matrices is needed. For this controller to have arbitrary positive gains, it is sufficient that only a sign condition on system matrices should be satisfied. To assure that the states of the network are close to the average state, the problem of deviation minimization is solved in addition, using a novel extremum seeking algorithm.
TAC_paper_average_control_black.pdf (2.14 Mo) Télécharger le fichier
hal-03170606 , version 1 (16-03-2021)
Denis Nikitin, Carlos Canudas de Wit, Paolo Frasca. Control of Average and Deviation in Large-Scale Linear Networks. IEEE Transactions on Automatic Control, 2022, 67 (4), pp.1639-1654. ⟨10.1109/TAC.2021.3065191⟩. ⟨hal-03170606⟩
99 Consultations
135 Téléchargements
