Color-based Fusion of MRI Modalities for Brain Tumor Segmentation
Most attempts to provide automatic techniques to detect and locate suspected tumors in Magnetic Resonance images (MRI) concentrate on a single MRI modality. Radiologists typically use multiple MRI modalities for such tasks. In this paper, we report on experiments for automatic detection and segmentation of tumors in which multiple MRI modalities are encoded using classical color encodings. We investigate the use of 2D convolutional networks using a classic U-Net architecture. Slice-by-slice MRI analysis for tumor detection is challenging because this task requires contextual information from 3D tissue structures. However, 3D convolutional networks are prohibitively expensive to train. To overcome this challenge, we extract a set of 2D images by projecting the 3D volume of MRI with maximum contrast. Multiple MRI modalities are then combined as independent colors to provide a color-encoded 2D image. We show experimentally that this led to better performance than slice-by-slice training while limiting the number of trainable parameters and the requirement for training data to a reasonable limit.
Color_based_Fusion_of_MRI_Modalities_for_Brain_Tumor_Segmentation.pdf (613.09 Ko)
Télécharger le fichier
main.pdf (608.99 Ko)
