Robust optimal periodic control using guaranteed Euler's method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider the application of optimal periodic control sequences to switched dynamical systems. The control sequence is obtained using a finite-horizon optimal method based on dynamic programming. We then consider Euler approximate solutions for the system extended with bounded perturbations. The main result gives a simple condition on the perturbed system for guaranteeing the existence of a stable limit cycle of the unperturbed system. An illustrative numerical example is provided which demonstrates the applicability of the method.
hal-03174207 , version 1 (19-03-2021)
Copyright (Tous droits réservés)
Jawher Jerray, Laurent Fribourg, Étienne André. Robust optimal periodic control using guaranteed Euler's method. ACC 2021 - American Control Conference, May 2021, New Orleans/Virtual, United States. pp.986-991, ⟨10.23919/ACC50511.2021.9482621⟩. ⟨hal-03174207⟩
74 Consultations
0 Téléchargements
