Draft: sOMP: NUMA and cache-aware simulations for task-based applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2021
Brouillon: sOMP: simulations prenant en charge le cache et les effets NUMA pour les applications à base de tâches
Anticipating the behavior of applications, studying, and designing algorithms are some of the most important purposes for the performance and correction studies about simulations and applications relating to intensive computing. Many frameworks were designed to simulate large distributed computing infrastructures and the applications running on them. At the node level, some frameworks have also been proposed to simulate task-based parallel applications. However, one missing critical capability from these works is the ability to take Non-Uniform Memory Access (NUMA) effects into account, even though virtually every HPC platform nowadays exhibits such effects. We thus enhance an existing simulator for dependency-based task-parallel applications, that enables experimenting with multiple data locality models. We also introduce two localityaware performance models: we update a lightweight communication-oriented model that uses topology information to weight data transfers, and introduce a more complex communications and cache model that takes into account data storage in the LLC. We validate both models on dense linear algebra test cases and show that, on average, our simulator reproducibly predicts execution time with a small relative error.
Anticiper le comportement des applications, étudier et concevoir des algorithmes sont parmi les objectifs les plus importants des études de performance et de correction sur les simulations et les applications liées au calcul intensif. De nombreux outils ont été conçus pour simuler de grandes infrastructures informatiques distribuées et les applications qui y sont exécutées. Au niveau du nœud, certains outils ont également été proposés pour simuler des applications parallèles à base de tâches. Cependant, une capacité critique manquante à ces travaux est de pouvoir prendre en compte les effets NUMA (Non-Uniform Memory Access), alors que pratiquement toutes les plates-formes HPC présentent aujourd’hui de tels effets. Nous améliorons ici un simulateur pour les applications parallèles à base de tâches avec dépendances, qui permet d’expérimenter plusieurs modèles de localité de données. Nous introduisons également deux modèles de performances: nous améliorons un modèle orienté communication léger, et nous introduisons un modèle de communication et de cache plus complexe qui prend en compte le stockage des données dans le LLC. Nous validons les deux modèles sur des cas test d’algèbre linéaire dense et montrons qu’en moyenne, notre simulateur prédit de manière reproductible le temps d’exécution avec une erreur relative faible.
RR-9400.pdf (801.51 Ko) Télécharger le fichier
hal-03177026 , version 1 (22-03-2021)
hal-03177026 , version 2 (29-04-2021)
  • HAL Id : hal-03177026 , version 2
Idriss Daoudi, Samuel Thibault, Thierry Gautier. Draft: sOMP: NUMA and cache-aware simulations for task-based applications. [Research Report] RR-9400, Inria. 2021, pp.25. ⟨hal-03177026v2⟩
186 Consultations
305 Téléchargements
