A Mathematical Bias - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
A Mathematical Bias
Any Mathematical framework inside which we formalize explanations limits the scope of behaviors we may consider and the type of explanations we might provide. The problem is even more acute when a model provides accurate predictions. This naturally leads us to restrict our investigation within the chosen framework, making us blind to alternatives.
Neurosciences
draft.pdf (60.41 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-03184805 , version 1 (29-03-2021)
  • HAL Id : hal-03184805 , version 1
Nicolas P. Rougier, Cédric Brun, Thomas Boraud. A Mathematical Bias. 2021. ⟨hal-03184805⟩
166 Consultations
222 Téléchargements
