Closed space-filling curves with controlled orientation for 3D printing - Archive ouverte HAL Access content directly
Journal Articles Computer Graphics Forum Year : 2022
(1) , (2, 3) , (1) , (4) , (4) , (1)
1
2
3
4
Jonàs Martínez
Rahnuma Islam Nishat
  • Function : Author
  • PersonId : 1116081
Sue Whitesides
  • Function : Author
  • PersonId : 868787
Sylvain Lefebvre
  • Function : Author
  • PersonId : 861797
We explore the optimization of closed space-filling curves under orientation objectives. By solidifying material along the closed curve, solid layers of 3D prints can be manufactured in a single continuous extrusion motion. The control over orientation enables the deposition to align with specific directions in different areas, or to produce a locally uniform distribution of orientations, patterning the solidified volume in a precisely controlled manner.Our optimization framework proceeds in two steps. First, we cast a combinatorial problem, optimizing Hamiltonian cycles within a specially constructed graph. We rely on a stochastic optimization process based on local operators that modify a cycle while preserving its Hamiltonian property. Second, we use the result to initialize a geometric optimizer that improves the smoothness and uniform coverage of the cycle while further optimizing for alignment and orientation objectives.
ClosedSpaceFillingCurve.pdf (17.77 Mo) Télécharger le fichier
Dates and versions
hal-03185200 , version 1 (30-03-2021)
hal-03185200 , version 2 (19-04-2022)
Identifiers
Cite
Adrien Bedel, Yoann Coudert-Osmont, Jonàs Martínez, Rahnuma Islam Nishat, Sue Whitesides, et al.. Closed space-filling curves with controlled orientation for 3D printing. Computer Graphics Forum, In press, ⟨10.1111/cgf.14488⟩. ⟨hal-03185200v2⟩
541 View
741 Download
Share
