Formally verified speculation and deoptimization in a JIT compiler - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Proceedings of the ACM on Programming Languages Année : 2021
Just-in-time compilers for dynamic languages routinely generate code under assumptions that may be invalidated at run-time, this allows for specialization of program code to the common case in order to avoid unnecessary overheads due to uncommon cases. This form of software speculation requires support for deoptimization when some of the assumptions fail to hold. This paper presents a model just-in-time compiler with an intermediate representation that explicits the synchronization points used for deoptimization and the assumptions made by the compiler's speculation. We also present several common compiler optimizations that can leverage speculation to generate improved code. The optimizations are proved correct with the help of a proof assistant. While our work stops short of proving native code generation, we demonstrate how one could use the verified optimization to obtain significant speed ups in an end-to-end setting.
popl21main-p383-p-e6099d7-48645-final.pdf (398.42 Ko) Télécharger le fichier
hal-03185848 , version 1 (30-03-2021)
Aurèle Barrière, Sandrine Blazy, Olivier Flückiger, David Pichardie, Jan Vitek. Formally verified speculation and deoptimization in a JIT compiler. Proceedings of the ACM on Programming Languages, 2021, 5 (POPL), pp.26. ⟨10.1145/3434327⟩. ⟨hal-03185848⟩
357 Consultations
268 Téléchargements
