Robotic needle steering in deformable tissues with extreme learning machines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Control strategies for robotic needle steering in soft tissues must account for complex interactions between the needle and the tissue to achieve accurate needle tip positioning. Recent findings show faster robotic command rate can improve the control stability in realistic scenarios. This study proposes the use of Extreme Learning Machines to provide fast commands for robotic needle steering. A synthetic dataset based on the inverse finite element simulation control framework is used to train the model. Results show the model is capable to infer commands 66% faster than the inverse simulation and reaches acceptable precision even on previously unseen trajectories.
Robotic_needle_steering_in_deformable_tissues_with_extreme_learning_machines.pdf (246.07 Ko) Télécharger le fichier
hal-03187930 , version 1 (01-04-2021)
Pedro Henrique Suruagy Perrusi, Anna Cazzaniga, Paul Baksic, Eleonora Tagliabue, Elena de Momi, et al.. Robotic needle steering in deformable tissues with extreme learning machines. AUTOMED 2021 - Automation in Medical Engineering, Jun 2021, Basel, Switzerland. ⟨hal-03187930⟩
286 Consultations
147 Téléchargements
