A Resource Perspective on E-Waste: A Global Problem with Local Solutions?
ICT is, at least to some extent, material, and different phases of the ICT lifecycle present us with different challenges related to the physical properties of ICT. E-waste is a term used to describe discarded electronic and electrical equipment that is neither reused or repaired, nor refurbished. While it is clear that e-waste is currently mainly a big social and environmental problem, we also see opportunities in re-introducing materials from existing e-waste into the ICT supply chain. Although e-waste is a pressing problem, it can also be seen as, and become a resource. The shift in perspective required is towards a life-cycle perspective on all materials in the production, marketing, and end-of-life processes of ICT artefacts. A combination of Design for Repairability and End-of-life Design can contribute to a set of electronics design guidelines that would meet circular economy principles.
Informatique [cs]
