Towards off-the-grid algorithms for total variation regularized inverse problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce an algorithm to solve linear inverse problems regularized with the total (gradient) variation in a gridless manner. Contrary to most existing methods, that produce an approximate solution which is piecewise constant on a fixed mesh, our approach exploits the structure of the solutions and consists in iteratively constructing a linear combination of indicator functions of simple polygons.
main.pdf (1.64 Mo) Télécharger le fichier
hal-03196916 , version 1 (13-04-2021)
hal-03196916 , version 2 (03-11-2021)
Yohann de Castro, Vincent Duval, Romain Petit. Towards off-the-grid algorithms for total variation regularized inverse problems. 8th International Conference on Scale Space and Variational Methods in Computer Vision (SSVM 2021), May 2021, Online event, France. pp.553-564, ⟨10.1007/978-3-030-75549-2_44⟩. ⟨hal-03196916v1⟩
272 Consultations
299 Téléchargements
