The Laplacian Spectrum of Large Graphs Sampled from Graphons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Network Science and Engineering Année : 2021
This paper studies the Laplacian spectrum and the average effective resistance of (large) graphs that are sampled from graphons. Broadly speaking, our main finding is that the Laplacian eigenvalues of a large dense graph can be effectively approximated by using the degree function of the corresponding graphon. More specifically, we show how to approximate the distribution of the Laplacian eigenvalues and the average effective resistance (Kirchhoff index) of the graph. For all cases, we provide explicit bounds on the approximation errors and derive the asymptotic rates at which the errors go to zero when the number of nodes goes to infinity. Our main results are proved under the conditions that the graphon is piecewise Lipschitz and bounded away from zero.
The Laplacian Spectrum of Large Graphs Sampled from Graphons.pdf (1.85 Mo) Télécharger le fichier
hal-03197046 , version 1 (13-04-2021)
Renato Vizuete, Federica Garin, Paolo Frasca. The Laplacian Spectrum of Large Graphs Sampled from Graphons. IEEE Transactions on Network Science and Engineering, 2021, 8 (2), pp.1711-1721. ⟨10.1109/TNSE.2021.3069675⟩. ⟨hal-03197046⟩
132 Consultations
121 Téléchargements
