Evaluating sediment and water sampling methods for the estimation of deep-sea biodiversity using environmental DNA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Scientific Reports Année : 2021
Nicolas Henry
Patrick Wincker
Daniela Zeppilli
  • Fonction : Auteur
  • PersonId : 952103
Despite representing one of the largest biomes on earth, biodiversity of the deep seafloor is still poorly known. Environmental DNA metabarcoding offers prospects for fast inventories and surveys, yet requires standardized sampling approaches and careful choice of environmental substrate. Here, we aimed to optimize the genetic assessment of prokaryote (16S), protistan (18S V4), and metazoan (18S V1-V2, COI) communities, by evaluating sampling strategies for sediment and aboveground water, deployed simultaneously at one deep-sea site. For sediment, while size-class sorting through sieving had no significant effect on total detected alpha diversity and resolved similar taxonomic compositions at the phylum level for all markers studied, it effectively increased the detection of meiofauna phyla. For water, large volumes obtained from an in situ pump (~ 6000 L) detected significantly more metazoan diversity than 7.5 L collected in sampling boxes. However, the pump being limited by larger mesh sizes (> 20 µm), only captured a fraction of microbial diversity, while sampling boxes allowed access to the pico- and nanoplankton. More importantly, communities characterized by aboveground water samples significantly differed from those characterized by sediment, whatever volume used, and both sample types only shared between 3 and 8% of molecular units. Together, these results underline that sediment sieving may be recommended when targeting metazoans, and aboveground water does not represent an alternative to sediment sampling for inventories of benthic diversity.
s41598-021-86396-8.pdf (1.18 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03198097 , version 1 (14-04-2021)
Miriam I Brandt, Florence Pradillon, Blandine Trouche, Nicolas Henry, Cathy Liautard-Haag, et al.. Evaluating sediment and water sampling methods for the estimation of deep-sea biodiversity using environmental DNA. Scientific Reports, 2021, 11 (1), pp.7856. ⟨10.1038/s41598-021-86396-8⟩. ⟨hal-03198097⟩
155 Consultations
85 Téléchargements
