IOOpt: Automatic Derivation of I/O Complexity Bounds for Affine Programs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
Evaluating the complexity of an algorithm is an important step when developing applications, as it impacts both its time and energy performance. Computational complexity, which is the number of dynamic operations regardless of the execution order, is easy to characterize for affine programs. Data movement (or, I/O) complexity is more complex to evaluate as it refers, when considering all possible valid schedules, to the minimum required number of I/O between a slow (e.g. main memory) and a fast (e.g. local scratchpad) storage location. This paper presents IOOpt, a fully automated tool that automatically bounds the data movement of an affine (tilable) program. Given a tilable program described in a DSL, it automatically computes: 1. a lower bound of the I/O complexity as a symbolic expression of the cache size and program parameters; 2. an upper bound that allows one to assess the tightness of the lower bound; 3. a tiling recommendation (loop permutation and tile sizes) that matches the upper bound. For the lower bound algorithm which can be applied to any affine program, a substantial effort has been made to provide bounds that are as tight as possible for neural networks: In particular, it extends the previous work of Olivry et al. to handle multi-dimensional reductions and expose the constraints associated with small dimensions that are present in convolutions. For the upper bound algorithm that reasons on the tile band of the program (e.g. output of a polyhedral compiler such as PluTo), the algebraic computations involved have been tuned to behave well on tensor computations such as direct tensor contractions or direct convolutions. As a bonus, the upper bound algorithm that has been extended to multi-level cache can provide the programmer with a useful tiling recommendation. We demonstrate the effectiveness of our tool by deriving the symbolic lower and upper bounds for several tensor contraction and convolution kernels. Then we evaluate numerically the tightness of our bound using the convolution layers of Yolo9000 and representative tensor contractions from the TCCG benchmark suite. Finally, we show the pertinence of our I/O complexity model by reporting the running time of the recommended tiled code for the convolution layers of Yolo9000.
main.pdf (1.32 Mo) Télécharger le fichier
hal-03200539 , version 1 (16-04-2021)
hal-03200539 , version 2 (08-07-2021)
  • HAL Id : hal-03200539 , version 1
Auguste Olivry, Guillaume Iooss, Nicolas Tollenaere, Atanas Rountev, P Sadayappan, et al.. IOOpt: Automatic Derivation of I/O Complexity Bounds for Affine Programs. 2021. ⟨hal-03200539v1⟩
268 Consultations
359 Téléchargements
