Abstract : Passive Optical Networks (PONs) are an economically efficient means of providing high bandwidth services to end users because end-points can share the cost and the benefit of fibre optic connection. There is a growing interest in the use of PONs as a bearer for services such as Long Term Evolution (LTE), however work remains to be done to ensure stable, low latency and low packet loss for full duplex Transmission. In this paper we are mostly concerned with the characteristics of the downstream channel so as to further the case for PON sharing. We review typical downstream schedulers used in the industry and propose a three-stage downstream scheduler that assures quality of service, accurately, across Virtual Network Operators (VNOs) in multi-tenant PONs environment. We benchmark our scheduler against other algorithms, obtaining almost ideal scheduling performance.
https://hal.inria.fr/hal-03200648 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, April 16, 2021 - 5:05:45 PM Last modification on : Friday, April 16, 2021 - 5:38:41 PM Long-term archiving on: : Saturday, July 17, 2021 - 7:06:51 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2023-01-01
Frank Slyne, Bruno Cornaglia, Marco Boselli, Marco Ruffini. 3-Stage Hierarchical Quality of Service for Multi-tenant Passive Optical Networks. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.193-203, ⟨10.1007/978-3-030-38085-4_17⟩. ⟨hal-03200648⟩
