HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Machine Learning Assisted Quality of Transmission Estimation and Planning with Reduced Margins
Abstract : In optical transport networks, the Quality of Transmission (QoT) using a physical layer model (PLM) is estimated before establishing new or reconfiguring established optical connections. Traditionally, high margins are added to account for the model’s inaccuracy and the uncertainty in the current and evolving physical layer conditions, targeting uninterrupted operation for several years, until the end-of-life (EOL). Reducing the margins increases network efficiency but requires accurate QoT estimation. We present two machine learning (ML) assisted QoT estimators that leverage monitoring data of existing connections to understand the actual physical layer conditions and achieve high estimation accuracy. We then quantify the benefits of planning/upgrading a network over multiple periods with accurate QoT estimation as opposed to planning with EOL margins.
Complete list of metadata
https://hal.inria.fr/hal-03200661
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, April 16, 2021 - 5:06:43 PM
Last modification on : Friday, April 16, 2021 - 5:38:31 PM
Long-term archiving on: : Saturday, July 17, 2021 - 7:11:40 PM
File
 Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed until : 2023-01-01
Please log in to resquest access to the document
Identifiers
Citation
Konstantinos Christodoulopoulos, Ippokratis Sartzetakis, Polizois Soumplis, Emmanouel Varvarigos. Machine Learning Assisted Quality of Transmission Estimation and Planning with Reduced Margins. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.211-222, ⟨10.1007/978-3-030-38085-4_19⟩. ⟨hal-03200661⟩
Share
Metrics
Record views
31
