Abstract : The introduction of all-optical switching in data center interconnection networks (DCN) is key to addressing some of the shortcomings of state-of-the-art electronic switched solutions. Limitations in the port count, reconfiguration speed and cost of optical switches, however, require novel optical switching and DCN designs. We present the concept of a simplified DCN fabric that relies on a lean optical switch design of limited but scalable functionality that offers high reconfiguration speeds, real-time scheduling, efficient control and low equipment cost. To achieve these objectives, the proposed architecture relaxes the usual non-blocking switching requirements but opts for switching modules that are constrained in terms of the achievable space and wavelength input-output configurations. We analytically compare the functionality and complexity of the simplified fabric with those of a non-blocking switch. We evaluate the throughput performance of the simplified DCN fabric and compare it to that of other fabrics with a different level of functionality and centralized control.
https://hal.inria.fr/hal-03200671 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, April 16, 2021 - 5:07:19 PM Last modification on : Friday, April 16, 2021 - 5:38:26 PM Long-term archiving on: : Saturday, July 17, 2021 - 7:11:46 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2023-01-01
Konstantinos Kontodimas, Kostas Christodoulopoulos, Emmanouel Varvarigos. Simplifying Optical DCN Fabrics with Blocking Space Switching and Wavelength-Constrained WDM. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.286-298, ⟨10.1007/978-3-030-38085-4_25⟩. ⟨hal-03200671⟩
