Abstract : Spectrally-spatially flexible optical networks (SS-FONs) are proposed as a solution for future traffic requirements in optical backbone networks. As SS-FONs operate within flex-grid, the provisioning of lightpaths spanning multiple frequency slots results in spectrum fragmentation, especially in presence of dynamic traffic. Fragmentation, in turn, may lead to blocking of dynamic requests due to the lack of sufficiently-large free spectral windows. In this paper, to reach a better understanding of fragmentation in SS-FON, we extend several metrics used in (single-core) elastic optical networks to measure the fragmentation in SS-FONs. Next, we apply these metrics to a dynamic-routing algorithm with the goal of minimizing bandwidth blocking. Finally, we analyze the impact of spatial continuity constraint (SCC) on the network fragmentation. Simulations run on two representative network topologies show that the root mean square factor metric yields the best performance in terms of blocking when compared to other analyzed metrics.
https://hal.inria.fr/hal-03200685 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, April 16, 2021 - 5:08:04 PM Last modification on : Friday, April 16, 2021 - 5:38:19 PM Long-term archiving on: : Saturday, July 17, 2021 - 7:11:52 PM
File
Restricted access
To satisfy the distribution rights of the publisher, the document is embargoed
until : 2023-01-01
Piotr Lechowicz, Massimo Tornatore, Adam Włodarczyk, Krzysztof Walkowiak. Fragmentation Metrics in Spectrally-Spatially Flexible Optical Networks. 23th International IFIP Conference on Optical Network Design and Modeling (ONDM), May 2019, Athens, Greece. pp.235-247, ⟨10.1007/978-3-030-38085-4_21⟩. ⟨hal-03200685⟩
