Shared-Memory Communication for Containerized Workflows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tanner Hobson
  • Fonction : Auteur
  • PersonId : 1096317
Orcun Yildiz
  • Fonction : Auteur
  • PersonId : 1029719
Bogdan Nicolae
Jian Huang
  • Fonction : Auteur
  • PersonId : 1096318
Tom Peterka
  • Fonction : Auteur
  • PersonId : 1096319
Scientific computation increasingly consists of a workflow of interrelated tasks. Containerization can make workflow systems more manageable, reproducible, and portable, but containers can impede communication due to their focus on encapsulation. In some circumstances, shared-memory regions are an effective way to improve performance of workflows; however sharing memory between containerized workflow tasks is difficult. In this work, we have created a software library called Dhmem that manages shared memory between workflow tasks in separate containers, with minimal code change and performance overhead. Instead of all code being in the same container, Dhmem allows a separate container for each workflow task to be constructed completely independently. Dhmem enables additional functionality: easy integration in existing workflow systems, communication configuration at runtime based on the environment, and scalable performance.
Shared-Memory_Communication_for_Containerized_Workflows.pdf (441.14 Ko) Télécharger le fichier
hal-03200931 , version 1 (17-04-2021)
  • HAL Id : hal-03200931 , version 1
Tanner Hobson, Orcun Yildiz, Bogdan Nicolae, Jian Huang, Tom Peterka. Shared-Memory Communication for Containerized Workflows. CCGrid'21: The 21th IEEE/ACM International Symposium on Cluster, Cloud and Internet Computing, May 2021, Melbourne, Australia. ⟨hal-03200931⟩
Collections
JLESC
82 Consultations
1010 Téléchargements
