Stable GSTC formulation for Maxwell’s equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Antennas and Propagation Année : 2022
We revisit the classical zero-thickness Generalized Sheet Transition Conditions (GSTCs) which are a key tool for efficiently designing metafilms able to control the flow of light in a desired way. It is shown that it is more convenient to use an enlarged formulation of the GSTC in which the original metafilm is replaced by GSTCs that exclude the layer from the physical or computational domain. These new "layer" transition conditions have the same form as their "sheet" analogues hence they do not necessitate additional complications in their use; their advantage is that they provide a well-posed problem hence guaranty the stability of numerical schemes in the timedomain. These assessments are demonstrated for an all-dielectric structure; the effective susceptibility tensors are derived thanks to asymptotic analysis combined with homogenization technique and bounds for the susceptibilities entering the balance of energy are provided. While negative constant susceptibilities appear in the classical zero-thickness GSTCs, their values in the enlarged formulation are always positive which ensure the stability of the effective problem. Validation of the effective model is provided by means of comparison with direct numerics in two and three dimensions.
LebbePhamMaurel.pdf (17.08 Mo) Télécharger le fichier
hal-03203013 , version 1 (20-04-2021)
Paternité
N. Lebbe, Kim Pham, Agnès Maurel. Stable GSTC formulation for Maxwell’s equations. IEEE Transactions on Antennas and Propagation, 2022, 70 (8), pp.6825-6840. ⟨10.1109/TAP.2022.3161436⟩. ⟨hal-03203013⟩
358 Consultations
244 Téléchargements
