Investigation of the impact of normalization on the study of interactions between myocardial shape and deformation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Myocardial shape and deformation are two relevant descriptors for the study of cardiac function and can undergo strong interactions depending on diseases. Manifold learning provides low dimensional representations of these high-dimensional descriptors, but the choice of normalization can strongly affect the analysis. Besides, whether the shape normalization should include a scale factor is still an open question. In this paper, we investigate the influence of normalization choices on the study of the interactions between cardiac shape and deformation using Multiple Manifold Learning, a dimensionality reduction method that considers inter-and intra-descriptors link between samples. By studying the main variations of two different shape normalizations (one including scaling, the other one not) we observed that the scaled normalization concentrates variations of a given physiological characteristic on only one mode. The influence of the associated choice of the deformation normalization was evaluated by quantifying differences between the estimated low-dimensional spaces (one for each choice against a combination of both), revealing potential analysis biases that may arise depending on such choices.
Difolco_FIMH_2021.pdf (2.48 Mo) Télécharger le fichier
hal-03203378 , version 1 (20-04-2021)
Maxime Di Folco, Nicolas Guigui, Patrick Clarysse, Pamela Moceri, Nicolas Duchateau. Investigation of the impact of normalization on the study of interactions between myocardial shape and deformation. FIMH 2021 - 11th International Conference on Functional Imaging and Modeling of the Heart, Jun 2021, Stanford, United States. pp.223-231, ⟨10.1007/978-3-030-78710-3_22⟩. ⟨hal-03203378⟩
86 Consultations
104 Téléchargements
