Signal-Based Self-Organization of a Chain of UAVs for Subterranean Exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Frontiers in Robotics and AI Année : 2021
Miniature multi-rotors are promising robots for navigating subterranean networks, but maintaining a radio connection underground is challenging. In this paper, we introduce a distributed algorithm, called U-Chain (for Underground-chain), that coordinates a chain of flying robots between an exploration drone and an operator. Our algorithm only uses the measurement of the signal quality between two successive robots and an estimate of the ground speed based on an optic flow sensor. It leverages a distributed policy for each UAV and a Kalman filter to get reliable estimates of the signal quality. We evaluate our approach formally and in simulation, and we describe experimental results with a chain of 3 real miniature quadrotors (12 by 12 cm) and a base station.
frobt-08-614206.pdf (2.09 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03209269 , version 1 (27-04-2021)
Paternité
Pierre Laclau, Vladislav Tempez, Franck Ruffier, Enrico Natalizio, Jean-Baptiste Mouret. Signal-Based Self-Organization of a Chain of UAVs for Subterranean Exploration. Frontiers in Robotics and AI, 2021, 8, ⟨10.3389/frobt.2021.614206⟩. ⟨hal-03209269⟩
189 Consultations
152 Téléchargements
