HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Preprints, Working Papers, ...
Computing the Hilbert Class Fields of Quartic CM Fields Using Complex Multiplication
Jared Asuncion 1, 2, 3
Abstract : Let K be a quartic CM field, that is, a totally imaginary quadratic extension of a real quadratic number field. In a 1962 article titled On the classfields obtained by complex multiplication of abelian varieties, Shimura considered a particular family {F_K(m) : m ∈ Z >0 } of abelian extensions of K, and showed that the Hilbert class field H_K of K is contained in F_K(m) for some positive integer m. We make this m explicit. We then give an algorithm that computes a set of defining polynomials for the Hilbert class field using the field F_K(m). Our proof-of-concept implementation of this algorithm computes a set of defining polynomials much faster than current implementations of the generic Kummer algorithm for certain examples of quartic CM fields.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-03210279
Contributor : Jared Asuncion Connect in order to contact the contributor
Submitted on : Tuesday, April 27, 2021 - 8:28:56 PM
Last modification on : Wednesday, February 2, 2022 - 3:54:33 PM
paper1b.pdf
Identifiers
  • HAL Id : hal-03210279, version 1
  • ARXIV : 2104.13639
Collections
Citation
Jared Asuncion. Computing the Hilbert Class Fields of Quartic CM Fields Using Complex Multiplication. 2021. ⟨hal-03210279⟩
Share
Metrics
Record views
62
Files downloads
57
