Zermelo-Markov-Dubins with two trailers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2021
We study the minimum time problem for a simplified model of a ship towing a long spread of cables. Constraints are on the curvature of the trajectory as well as on the shape of what represent the spread of cables here. This model turns out to be the same as a cart towing two trailers and rolling without sleeping on a plane in uniform translation. The Hamiltonian system resulting from Pontryagin Maximum principle is not integrable.
lhmnlc21.pdf (269.97 Ko) Télécharger le fichier
hal-03211710 , version 1 (29-04-2021)
hal-03211710 , version 2 (04-05-2021)
hal-03211710 , version 3 (23-07-2021)
  • HAL Id : hal-03211710 , version 1
Ludovic Sacchelli, Jean-Baptiste Caillau, Thierry Combot, Jean-Baptiste Pomet. Zermelo-Markov-Dubins with two trailers. 2021. ⟨hal-03211710v1⟩
195 Consultations
144 Téléchargements
