Real-time flow estimation from reduced order models and sparse measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To successfully monitor and actively control hydrody-namic and aerodynamic systems (e.g. aircraft wings), it can be critical to estimate and predict the unsteady flow around them in real-time. Thus, we introduce a new algorithm to couple on-board measurements with fluid dynamics simulations and prior data in real-time without the need to rely on large computational infrastructure. This is achieved through a combination of a Proper Orthogonal Decomposition Galerkin method, stochastic closure-model under location uncertainty-and a particle filtering scheme. Impressive numerical results have been obtained for a 3-dimensional wake flows at moderate Reynolds for up to 14 vortex shedding cycles after the learning window , using a single measurement point.
Paper_Aero2020.pdf (499.3 Ko) Télécharger le fichier
hal-02969086 , version 2 (16-10-2020)
hal-02969086 , version 1 (29-04-2021)
hal-02969086 , version 3 (14-10-2021)
  • HAL Id : hal-02969086 , version 3
Agustin Martin Picard, Matheus Ladvig, Valentin Resseguier, Dominique Heitz, Etienne Mémin, et al.. Real-time flow estimation from reduced order models and sparse measurements. AERO 2020+1, Apr 2021, Visioconference, France. ⟨hal-02969086v3⟩
310 Consultations
296 Téléchargements
