HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Geo-Distribute Cloud Applications at the Edge
Abstract : With the arrival of the edge computing a new challenge arise for cloud applications: How to benefit from geo-distribution (locality) while dealing with inherent constraints of wide-area network links? The admitted approach consists in modifying cloud applications by entangling geo-distribution aspects in the business logic using distributed data stores. However, this makes the code intricate and contradicts the software engineering principle of externalizing concerns. We propose a different approach that relies on the modularity property of microservices applications: (i) one instance of an application is deployed at each edge location, making the system more robust to network partitions (local requests can still be satisfied), and (ii) collaboration between instances can be programmed outside of the application in a generic manner thanks to a service mesh. We validate the relevance of our proposal on a real use-case: geo-distributing OpenStack, a modular application composed of 13 million of lines of code and more than 150 services.
Complete list of metadata
https://hal.inria.fr/hal-03212421
Contributor : Marie Delavergne Connect in order to contact the contributor
Submitted on : Thursday, April 29, 2021 - 3:40:17 PM
Last modification on : Wednesday, April 27, 2022 - 4:18:08 AM
Long-term archiving on: : Friday, July 30, 2021 - 6:55:37 PM
File
europar2021.pdf
Identifiers
Citation
Ronan-Alexandre Cherrueau, Marie Delavergne, Adrien Lebre. Geo-Distribute Cloud Applications at the Edge. EURO-PAR 2021 - 27th International European Conference on Parallel and Distributed Computing, Aug 2021, Lisbon, Portugal. pp.1-14, ⟨10.1007/978-3-030-85665-6_19⟩. ⟨hal-03212421⟩
Share
Metrics
Record views
240
Files downloads
279
