HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Conference papers
Enhancing Wake-Up Receivers Reliability Through Preamble Filtering and Minimum Energy Coding
Abstract : Wake-up Receivers (WuRs) represent one of the most promising solutions for allowing an ultra low power consumption in wireless sensor networks. However, WuRs have several limitations such as low sensitivity, inducing a miss-interpret of the wake-up signal, and thus a performance degradation of the whole system. This work introduces two complementary schemes, namely minimum energy coding and preamble filtering, in order to enhance the WuR reliability while being energy efficient. It is shown through experimental measurements an enhancement on the reliability up to 22% and a total energy saving of 42% while applying minimum energy coding. Moreover, a significant reduction of the false wake-up is realized through preamble filtering.
Complete list of metadata
https://hal.inria.fr/hal-03216281
Contributor : Matthieu Gautier Connect in order to contact the contributor
Submitted on : Monday, May 3, 2021 - 9:18:01 PM
Last modification on : Thursday, May 5, 2022 - 3:32:37 AM
Long-term archiving on: : Wednesday, August 4, 2021 - 8:17:08 PM
File
djidi21iscas.pdf
Identifiers
  • HAL Id : hal-03216281, version 1
Citation
Nour El Hoda Djidi, Matthieu Gautier, Antoine Courtay, Olivier Berder. Enhancing Wake-Up Receivers Reliability Through Preamble Filtering and Minimum Energy Coding. IEEE International Symposium on Circuits and Systems (ISCAS), May 2021, Daegu, South Korea. ⟨hal-03216281⟩
Share
Metrics
Record views
24
Files downloads
121
