A high-resolution downscaled CMIP5 projections dataset of essential surface climate variables over the globe coherent with the ERA5 reanalysis for climate change impact assessments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Data in Brief Année : 2021
A high-resolution climate projections dataset is obtained by statistically downscaling climate projections from the CMIP5 experiment using the ERA5 reanalysis from the Copernicus Climate Change Service. This global dataset has a spatial resolution of 0.25°x 0.25°, comprises 21 climate models and includes 5 surface daily variables at monthly resolution: air temperature (mean, minimum, and maximum), precipitation, and mean near-surface wind speed. Two greenhouse gas emissions scenarios are available: one with mitigation policy (RCP4.5) and one without mitigation (RCP8.5). The downscaling method is a Quantile Mapping method (QM) called the Cumulative Distribution Function transform (CDF-t) method that was first used for wind values and is now referenced in dozens of peer-reviewed publications. The data processing includes quality control of metadata according to the climate modeling community standards and value checking for outlier detection.
1-s2.0-S2352340921001840-main.pdf (1.91 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-03218451 , version 1 (08-05-2021)
Paternité - Pas de modifications
Thomas Noël, Harilaos Loukos, Dimitri Defrance, Mathieu Vrac, Guillaume Levavasseur. A high-resolution downscaled CMIP5 projections dataset of essential surface climate variables over the globe coherent with the ERA5 reanalysis for climate change impact assessments. Data in Brief, 2021, 35, pp.106900. ⟨10.1016/j.dib.2021.106900⟩. ⟨hal-03218451⟩
175 Consultations
67 Téléchargements
