Comparison of Cycle Reduction and Model Reduction Strategies for the Design Optimization of Hybrid Powertrains on Driving Cycles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Energies Année : 2021
Mariam Ahmed
  • Fonction : Auteur
  • PersonId : 1098354
Robin Vincent
  • Fonction : Auteur
  • PersonId : 1098355
Decision-making is a crucial and difficult step in the design process of complex systems such as the hybrid powertrain. Finding an optimal solution requires the system feedback. This can be, depending on the granularity of the models at the component level, highly time-consuming. This is even more true when the system’s performance is determined by its control. In fact, various possibilities can be selected to deliver the required torque to the wheels during a driving cycle. In this work, two different design strategies are proposed to minimize the fuel consumption and the cost of the hybrid powertrain. Both strategies adopt the iterative framework which allows for the separation of the powertrain design problem and its control while leading to system optimality. The first approach is based on model reduction, while the second approach relies on improved cycle reduction techniques. They are then applied to a parallel hybrid vehicle case study, leading to important cost reduction in reasonable delays and are compared using different metrics.
2021_Kaloun_Comparison of Cycle Reduction and Model Reduction Strategies.pdf (2.56 Mo) Télécharger le fichier
hal-03222773 , version 1 (10-05-2021)
Adham Kaloun, Stephane Brisset, Maxime Ogier, Mariam Ahmed, Robin Vincent. Comparison of Cycle Reduction and Model Reduction Strategies for the Design Optimization of Hybrid Powertrains on Driving Cycles. Energies, 2021, 14 (4), pp.948. ⟨10.3390/en14040948⟩. ⟨hal-03222773⟩
48 Consultations
64 Téléchargements
